Electric Pump
briantroy
I'm looking for an electric pump for use on a 10 ft rib. I see a wide array of pumps available ranging from $8 to $300. It would have to be DC adaptable and hopefully either completely fill or get really close to filling the tubes all the way. Any suggestions?
G
Guest
Guest
Re: Electric Pump
get a bravo high pressure pump its 150 bucks. trust me I have used all kinds of pumps from small to shop vacs and that bravo is the best. it will come with clips to attach to a battery.If you want 9v, you can buy an adapter and swap the ends
Desode
Re: Electric Pump
You have the Turbo 2 stage (BTP) ? Or the Single (BP12) ?
Ballinamuck
Re: Electric Pump
I own that one, even bought it from amazon and that link. Great pump. I have a 9.5ft sib, what used to take me 30-40 minutes inflating now takes about 10. No more pumping with a mattress pump then topping off with the foot pump.
G
Guest
Guest
Re: Electric Pump
Thatsva knockoff from the bravo. Spend extra 20 bucks and get the bravo. I know people that has been using it for over 6 years and still runs great. If that speedy pump was 50 bucks then I would get the speedy one.
smashed
Re: Electric Pump
It is not cheaper, you have 22 bucks shipping from this seller. I have the same pump, I bought from boatstogo.com. Costed 145 including shipping. Works fine so far, I have used it approx 10 times on a 14'. Last time we inflated an air floor with it to about 10 psi, worked flawlessly.
I think the bravo pumps are around 200 bucks. Check defender.com.
Here is a link to a bravo pump with a digital manometer Scoprega Bravo BTP 12 Digital Inflation Pump
briantroy
Re: Electric Pump
Didn't see those shipping fees. Thanks. Do you inflate and then deflate after every use? I have heard mixed things about doing such.
smashed
Re: Electric Pump
In the blue box on the right it says "$135.00 + $22.00 shipping, In Stock. Sold by Seamax Marine Inflatable Boats".
I inflate and deflate, yes. Not happy with it, but no other option for storage. When deflating I use the pump and suck all the air out. The boat fits well in it's pouch this way (150 pound inflatable + 70 pound floor). The pump moves a lot of air in no time. Hope the yellow pump lasts at least 5-6 years.
smashed
Re: Electric Pump
What pressure do you need in the tubes? If you have a mariner 4, don't waste your money. That one is easily inflated in 20 minutes with the hand pump provided.
G
Guest
Guest
Re: Electric Pump
smashed, I recall Alfredo aka sinistre saying your pump was faster?
Sinistre1
Re: Electric Pump
It IS definitely faster (I have an older Bravo... but I did take it apart and looks like some of the rubber parts are getting softer. I re-tightened everything and at least the pressure part seems to be more like new :) Smashed' is still faster at the lower pressure setting by a bit.
At work.... arrrggghhhh!!!!
