Electric fuel pump
Pairadice
1986 Contessa 2850. Inmar 5.7 small block motor. Carter electric fuel pump. Should the fuel pump come on when you turn the ign. switch to on ? Mine doesn't comes on till you engage starter. But it works fine. I just always thought it should power up when the ign. switch is turned to on. I used a tester to see when pump got power.
