Electric Fuel Pump Instead Of Original
Aoldham08
Any opinions on installing a low pressure electric fuel pump with a recirculate tube to prevent overwhelming the needle and seats at idle. Basically it goes from the tank, to a check valve, a return tee, the pump, the bubble, an exit tee connected to return tee to create a circulating loop then on to the engine. In theory it should only provide fuel as required to fill the bowls. Has anyone tried this instead of going back to oem vacuum operated pump. Is it dangerous and crazy or genius. Let me know thanks. Adam
GA_Boater
Welcome aboard, Aoldham08
Gave you a thread of your own.
As emdsapmgr said, you need more than just the pump. If a fuel line breaks or other problem develops causing the motor to stop, an unsensed pump can fill the bilge with fuel. Not safe and a potentially expensive fuel spill could result.
