Electric choke is not working right
hydropenguin2011
I have a 1973 johnson 85 hp motor. when i engage the choke the selenoid moves as it is suppose too but on the other end of the linkage it does not appear to be moving anything at all. I know the manual choke works but on the lake it is hard to engage it on our boat. Is there a setting the manual switch has to be on for the electric choke to work or i don't know.
jim dozier
Re: Electric choke is not working right
Take a look at the end of the choke linkage that moves when the solenoid is actuated. It sounds like the end came loose from the choke butterfly arm.
hydropenguin2011
thanx that was it i just had to really look in there to see it. It started up after i got the choke working. I couldnt choke it so it wouldnt start. Now its fowling plugs faster than i can buy them.
jim dozier
Make sure you are using the correct heat range spark plug for your engine. Make sure the choke stays off during normal operation. Make sure your oil mix is correct at 50:1. If it still fouls plugs check the carbs, you may have a stuck open float causing it to run rich. Does the engine run OK at all rpms? Can you pump up the fuel bulb tight?
hydropenguin2011
the plugs are right and the fuek is mixed 50:1 and the bulb pressurizes and the choke is ok. we picked up the wole boat with the 2 motors for 1500 bc the guy who had owned it died and his son needed to get rid of it but it had sat for 2 0r 3 years. There may be bad gas still in the lines
