Elec shift throttle cable change/ control box
kptrapper
Sounds simple but I'm stuck. Need to change throttle cable from control box for mid 70's elec shift 115 'rude. Took cover off box and removed handle but cant figure out how to get cable off handle. Thanks for any help. Gary
hondon
Re: Elec shift throttle cable change/ control box
Is'nt there a little allen screw at the end of the cable ?
jimtodd72
There should be two allen screws attaching this to the throttle arm. There is one that you can see as you open up the control box and one on the underside of the arm so if you just lift it up and out, you'll see it. Don't make the same mistake I did...be sure that after you replace it, everything is seated properly and very tight. It's rough to find yourself on the lake with a very loose throtle control and no throttle response.<br /><br />Jim
