elec. shift johnson
double t
just traded for a old johnson60 ,boat and trailer was told that it would not run . i give her a drink of gas and a prayer and she fired right up and run the problem is the prop is stuck in forward could some of you guys explain to me how the elect shift works? is some thing siezed up ? its been sitting out in the weather since 1997 THANKS for any and all help :D
Yepblaze
Re: elec. shift johnson
Check the oil in the lower unit. It needs to be of special type as thin as ATF or something like it. And might need to be in the water before it shifts because it uses some sort of self internal powered hydraulic actuator and is electrically controlled. It may be the previous owner just had put the wrong oil in there.
double t
i will check the oil tomorrow but i know the boat and it was working when it was last in the water also i had it in a barrel of water when i ran it tanks
tremor
If the motor is a '68 or '69 55HP (like one I have) you'll need to check out the electric shifter first (check that lower end lube too). The motor is allways in Forward at rest, not neutrel. After starting, the lower end mounted shift solenoid places the trans into neutrel. A nice feature if you consider the potential consequences. <br />There's probably other electric start Johnsons of the period mentioned. But the one I mentioned may have 1 or 2 solenoids, depends on weather the exhaust runs through the prop or not.<br />When shutting these motors down, a defective rectifier/diode ( I think) can allow the unit to slam into forward before the engine stops, a sure sign that the worst has yet to come. This may have been the final symptom prior to the previous owner giving up. Ask him if you can. <br />Do some diagnostics & post the results & I'll dig out a repair manual if needed.
double t
ok i found what was the problem wasthe "netural switch" mounted in the shifter was cracked unwired the switch and then wired it straight problem solved thsnks so much for the help
