achris
More fish than mountain goat
- May 19, 2004
- 27,468
Re: Educate me again on prop efficiency
Just did a search on that calculator... It raises a few questions..
1. What unit of speed it to be used? (miles per hours, kilometres per hour, knots)
2. Where is the allowance for cupping?
3. Where is the input for prop diameter?
I didn't say the boat's performance was laughable, I said the resulting figures were laughable, as in 'just not possible'. That would require the props to be running at less than a 2 degree angle of attack... As I said, just not possible...
Nope.... It has nothing to do with the hull, it's all about the prop. It still needs to be 4 degrees (+/-1) to be 'efficient'. Less produces less thrust, thus being unable to efficiently use the available power, and more means power lost in overcoming to steep an angle of attack....
As I asked. Post up your pitch, diameter, boat speed, engine revs and drive ratio and I'll run them through my calculator....
Chris........
The slip results come from the BAM slip calculator.
jestor68 said:The fact that you consider my boat's excellent performance laughable is no concern to me.
jestor68 said:For the record, I did not suggest that Solas props were better than Mercury props. My testing indicates they are as good; and a better value since they cost on average $50 less in the aluminum category.
The fact is they equaled the Merc prop in efficiency and every one runs smoother than the original Merc prop.
My boat has a CAT hull, which might help account for it's pretty good numbers.
Chris........
