Eaton Viking Model 463 spark plug
djeady
I am trying to get mine going again. I would like to replace the spark plug, but am having trouble determining the correct plug I though this was the same as an Elto Ace which calls for a C7 or equivalent plug but when I tried an NGK AB-6 which is supposed to be the equivalent, the diameter of the threaded portion is too big.
The plug I had in it before was a Champion J-8, but I'm not certain that is the right plug.
Can anyone assist?
djeady
Also need some guidance on re-installing the armature base/ignition plate. Do I simply align the lever with the TDC notch on the shaft?
