EasyPoxy Without Primer ?
ICC
Gettting ready to spray some EasyPoxy over a glass hull and according to the Petit instructions they indicate that you can go over a clean sanded hull. The marine shop recommended that I prime first. Has anyone used the Petit EasyPoxy without priming first and if so were the results good ?
bidlimit
Re: EasyPoxy Without Primer ?
Hi<br /> I rolled and tipped easypoxy on a 14' outboard. I sanded her down to 400 grit and didn't use the primer and the first coat was challenging to say the least. I didn't get good coverage on teh first coat because the substrate was blue and it pulled through and streaked a lot. The second coat was OK but the primner and/or sanding it down only to 320 probably woulda helped the first coat. But by spraying you should be OK. It'll come out beautiful and durable either way.
bidlimit
Oh yea and i had no adhesion issues as well. 4 years and still strong...
BillP
Not a problem using easypoxy over gelcoat without priming.
ICC
Thanks for the info, going to give it a try and see how it works.
