Easy Pump Impeller question..
kameika
I recently did a full LU seal change--and took the opportunity to change the pump subassembly. For $55, it's worth the trouble.<br /><br />The engine is a 1987 OMC 225 Horsepower V6.<br /><br />Question, though: (I guess this is a confirmation of what I *think* I know..) The impeller arms are crammed back into the bell, and hence must "bend".<br /><br />Since the drive shaft turns clockwise on this engine; the impeller blades should face into the direction of rotation, or against this direction of rotation?<br /><br />Gosh, I hope I get the right answer; or I'll be re-working things.<br /><br />Many thanks,<br />Ken
JB
Re: Easy Pump Impeller question..
Howdy, Ken.<br /><br />The tips of the arms point back to where they were, or trail the reat of the impeller.<br /><br />Good luck. :)
kameika
Very good news..<br /><br />So, when you look down on the impeller, it looks like a little "hurricane" shape. A vane's stem LEADS the vane's tail.<br /><br />Correct?<br /><br />If so, I'll install my LU as soon as it gets warm (in New Jersey.)<br /><br />Thanks Much!<br /><br />Ken
rickdb1boat
As you put the impeller on the shaft, turn it in clockwise so the tips trail.<br /><br />EDIT: Put a little dish soap on the impeller cup to give it a head start when you turn it over to start it and make it easier ot install..
Chinewalker
Don't sweat it too much, as the first time you run the motor, it'll all straighten out to the correct position....<br />- Scott
kameika
Outstanding, gentlemen. I appreciate this.<br /><br />If the weather holds, the LU will be bolted-on this weekend.<br /><br />Ken
