BigShark527
Thread starter- Joined
- May 11, 2015
- 2
I need help!!! I have an early 80's Johnson 90 hp 4 cylinder that is not running on the bottom left cylinder. It has good compression (120), fire and fuel. I have it at a mechanic now and he is puzzled. We replaced the power pack because he said he i was weak and not firing consistently. He also swapped the coil. We have swapped plug wires and plugs from cylinder to cylinder as well as coils and still no life on the bottom left cylinder. He checked the reed valve yesterday and said that it was ok as well. The fire on the left side of the motor does look a bit weaker than the right side but there is spark there. He also said that everything checked ok with his meter under the flywheel. Any help or possible issues would be greatly appreciated as we have a vacation in less than 3 weeks and I am at a loss.
