Redfish_fisherman
Thread starter- Joined
- Jun 8, 2015
- 25
I have an early 1990's 150 HP Johnson Motor on a 17 ft Sea Pro. When I first bought the boat used, the boat was having a fuel issue that lead from one thing to another. The first issue was that once the motor reached RPM speed's of 5500 it would run for just a few minutes and then die off unless it was kicked back down to 4500-4800 RPM's and then ran fine. At the time the carberators were cleaned and the screen that is at the bottom of the pick up tube that goes into the gas tank was removed from the tube with a wire that I pushed down the pick up tube line to remove it. Also I replaced the fuel wator seperator and also installed all brand new fuel lines leading from the gas tank to the engine as well. After the gas lines were replaced, changed the spark plugs out to the OEM Champion brand spark plugs, and removed the screen that is at the bottom of the pick up line that goes into the gas tank, the engine started running better at 5200 RPMS just not at 5500. For the next couple trips it worked fine until the engine started to have an even worse fuel issues. NOTE: THIS BOAT IS BEING OPERATED AT A 2 STROKE 50:1 RATIO EVEN THOUGH IT DOES HAVE A VRO, BUT THE VRO IS NOT HOOKED UP AS FAR AS THE OIL PORTION.
long story short to this date the all Fuel lines replaced from tank to engine, fuel water seperator replaced, VRO fuel pump rebuilt (OIL PART NOT HOOKED UP 50:1 RATIO), Champion Brand spark plugs replaced, the Red Plug thing that is on the engine for the Choke was leaking so that was replaced. Carberators not cleaned out but the mechanic stated that they were clean when they inspected the drain plug from the bowls, and also the fuel lines dont seem to have any air leaks to allow air to go into the engine.
So what is going on right now after all of the things that have been replaced and fixed, the engine is still messing up and acting like the engine is not getting enough gas at full throttle. The engine will run at an idle speed in gear/out of gear for about 4-5 minutes without having to prime the primer ball. When the engine is at full throttle of half throttle while driving you hav to keep priming the primer ball in order to get it running. Im in the Marine Corps and have my daughter with me for the summer time and she has been wanting to go out on her daddy's new boat fishing all year and she get here and it not working right. Really need some help to resolve the issue or any reccomendations please help out.
