Eagle fish ID 2
Brian Hall
My uncle put it on my boat a few years ago and it doesn't work for some reason. The power will not come on. Would it be worth it to try to get it fixed or is this a cheap one that would cost more to fix than a new one?
Boatist
Re: Eagle fish ID 2
Txduckster<br /><br />First make sure you have power to the unit. Check for 12 volts on the power plug. Make sure do not have a simple problem like a blown inline fuse. Make sure the power connection is clean. Plug it in and out to try and clean up the connection.<br /><br />As far as repairing the unit if it is bad Eagle has a flat rate repair on units they are still repairing. More than likely they will offer your a discount on a later unit.<br /><br />Try the link below and give Eagle a call.<br /><br /> http://www.eaglegps.com/Support/Repair/default.htm
