TrdFrguson
Thread starter- Joined
- Mar 7, 2018
- 6
Hi everyone. Long time listener, first time caller.
So I acquired the above engine last year and it didn't run. So far I have replaced the spark plugs, spark plug wires, coil pack, and power pack. I have also rebuilt the carburetors (although I don't think fuel is responsible for the problem I am having now).
Also, I have a 40 hp Evinrude from the same year range that I have swapped the key ignition and control cables for (parts motor for me).
So, when I start the engine it usually requires a push or two to prime and then starts right up. Runs pretty rough for a bit and then dies out. If I open the idle lever some it will run a bit longer, but will still die. Eventually sludgy fuel mixture (I'm assuming) begins running out of the exhaust ports.
I have tried the power pack from the 40 hp, swapped spark plugs, swapped wires, checked all pins in connectors I could find, re-gapped the tang on the spark plug and the problem remains. When I ground a screwdriver to the terminal on the power pack I can get a spark when the screwdriver is approximately .005" and closer.
My neighbor has been kind enough to help me out and believes that the problem lies within a sensor and/or coil/magnet on the stator... I'm still trying to learn as I go (as you can probably tell by the way I am describing all of this), but any help would be greatly appreciated!!
Thanks to all!
Thanks to all!
