E25RCNB Water pump leak after re-install
jwarrenjr
I tore down the lower on a E25RCNB. All the seals have been reinstalled and I'm working on assembling the water pump. I ordered the kit "18-3383 - Water Pump Kit, With Housing 395270" and everything seems to fit back as it should. The issue that I'm having is when I attach the lower to a hose with an adapter on the water port, water is able to flow up the driveshaft. The lower gearcase view on MarineEngine's website lists seal #14 "18-2030 - Seal, 321786" that is supposed to fit in between the cup and the pump housing. 1st, the kit didn't come with that seal as it should if it's needed. 2nd There is absolutely no room to put the seal there. I've seen some videos of folks having a pump housing that the seal goes on the outside. Well, that part number seal doesn't fit there either. Additionally, I have a tube that fits in the pump housing and up the driveshaft about 3" give or take. Others have an o-ring on the inside of the housing, but I don't have a spot for for that either. There was no type of seal when I pulled it apart, but I can't really trust that since I found blue RTV EVERYWHERE on the inside as a previous owner tried anything but ordering proper parts. So who knows what else the did or didn't do?
I have some pictures and videos if needed. It really seams like some kind of seal is supposed to keep water from making it's way up the driveshaft and water tube. And i could see maybe how the water hose is applying too much pressure and forcing water through. BUT mind you, I turned the water on very slow and there is not much pressure at all needed.
Thank you in advance!
Joe Warren
flyingscott
The seal goes Between the stainless Cup and the housing. Is it pre installed? otherwise the # is
18-2030​
jwarrenjr
18-2030​
Did you look at the pictures below the video? I can post another angle if needed. If you could post something to show me how it goes that would be amazingly helpful!!!
I’m just not seeing how it would fit. The cup would literally be pushed out the thickness of the seal because there is no recess cut into the housing.
This is really frustrating, I’ve not seen anyone with the same type of housing that I have.
flyingscott
I think your fine , but call Sierra if your worried
jwarrenjr
I think you are right. I was testing it the way I did in the video because I didn't want to have everything assembled to find out water was pumping in and wrecking the gear case. Since I already had every single seal and bushing swapped out I put the lower on the motor without the gears or bottom part of the gear case. I learned a couple things.
1, there's 2 holes that allow water to come out in between the exhaust and transom from the top of the tube that goes up the drive shaft. Before I found those I was thinking the more water that was pumped, the more it would pump up the drive shaft. So now it's like why are there o-rings on a tube the gets dumped outside of the entire motor?
2, I found other models that have holes designed into the pumps so the system doesn't over pressure. I'm going to pretend like this is what is going on with my motor because when I put it together and turned the water on slowly, water started to slightly pee as it should. Cranked the motor up and water start coming out full blast!
So the pump works. No freaking clue why all this other stuff is happening, but it's pumping and it's not getting into the gear case!! I believe all requirements are checked. Next!
