Cameron119
- Oct 4, 2020
- 35
Good morning. Here we go again with my beloved 9.9 that I just cant seem to get purring like a kitten. I just finished rebuilding the lower unit by replacing the seals and gaskets to prevent water from leaking into the oil in the gearbox ( This went well ). I put the motor back together and struggled to get the shift linkage back together but made sure the highest point of the coupler was 7/16" proud of the lower unit casing. The shifting still feels a little rough from neutral to forward and the same from neutral to reverse.
Once the motor started up with the water on to the motor I noticed no water coming out of the telltale on the back. My first guess would be that I didn't properly align the hole in the top of the water pump with the tube that goes up towards the engine? Any help would be appreciated.
Secondly while in neutral and pulling the pull cord half of the time it would get stuck mid pull jarring my arm pretty hard. There is a small red arm that moves back and forth when shifting and it seems while I am pulling this gets caught on the flywheel notches(I have no idea how to fix this). I know I fixed the recoil spring about 5-6 years ago and it worked for quite some time with no issues.
Lastly I have this old gas tank but the fuel hose has newish connectors on the end. It doesn't seem to couple properly as it leaves about a 1/8" gap between the tank connection point and the connector that attaches to it as seen in the picture. Is it time for a new gas tank/hose assembly after all these years?
Any info would be appreciated as I am almost at my wits end with this motor. Its a love hate relationship but id hate to get rid of a gem like this.
Thanks
Cam
Thanks
Cam
