E-TEC Performance Report - the whole story
seahorse5
This was the title of a previous thread that got deleted due to a poster's attitude problem. For the rest of our readers, the following is the Bombardier response to a different post that about E-TEC performance reports and why the "prop formula math" did not jive with the recorded results.<br /><br />-----------------<br />Bombardier<br />Boats and Outboard Engines Division<br />250 Sea-Horse Drive <br />Waukegan, IL 60085 <br /><br />December 17, 2003<br /><br />Subject: E-TEC Performance Reports, Propellers and Gearcases<br /><br />We have received several requests for information regarding E-TEC performance reports as well as questions relating to the accuracy of data contained in those reports and some questions regarding our propellers and gearcases. The following is the result of our review.<br /><br />We asked our Application Engineers to review their field notes and compare the results to their spreadsheets and to the published Performance Reports. They have verified there are no mistakes or typographical errors in any of the documents. The data provided is accurate. Our Application Engineers use highly accurate instruments, such as digital tachometers, fuel flow meters, as well as gps and/or radar guns to collect the data for the Performance Reports published by Bombardier. The figures recorded in the Performance Data table are the average of several runs. These are accepted measurement devices and test standards used by other marine engine manufacturers as well as the boating media.<br /><br />We also invited our Propeller Engineer to address the propping concerns and slip numbers which have been derived from the performance reports: Slip is the most misunderstood of all propeller terms, almost certainly because it sounds like something that’s unwanted. Propeller slip is not a measure of propeller efficiency. Prop slip is the difference between actual and theoretical travel, resulting from a necessary propeller blade angle of attack. If the blade had no angle of attack, there would be no slip; but then there would be no positive and negative pressure created on the blades and therefore, there would be no thrust. To create thrust, in theory, there must be some angle of attack or slip. <br /><br />The objective of propeller design is to achieve the right amount of angle of attack. This is accomplished by matching the blade diameter and blade area to the existing engines horsepower and prop shaft rpm. Too much blade area or diameter will lower slip, but also lowers propeller efficiency, resulting in reduced performance (remember this last thought). <br /><br />When designing props, we start with: 1. what horsepower must it absorb, 2. what propshaft rpm do we want it to run at (based on gear ratio and operating range of the engine), and 3. what is the target boat speed for the application it will used in. We then measure or estimate the drag of the boat and the gearcase combined to give us the thrust that the prop must produce at the design speed. These values are then run through a computer using a propeller design program that calculates the optimum diameter, pitch and the blade loading for a specified blade area. From the output of the program, advance coefficient and prop efficiency can then be calculated.<br /> <br />This determines correct prop loading and allows us to manipulate the blade design, in very specific locations on the blade pressure face if necessary, to achieve the engine rpm and thrust we are targeting. That manipulation could be in blade flat, regression or progression and the difference from one area of the blade to the next could be .050" or less. It has a substantial effect on how the blade does its job.<br /><br />So, what is propeller efficiency? In simple terms, the power coming out of a prop divided by the power going into it, expressed as: Efficiency (%) = hp out / hp in x 100. <br /><br />To calculate hp out: hp out = boat speed (mph) x prop thrust (lbs) / 375<br />To calculate hp in; first calculate prop shaft speed: prop shaft rpm = engine rpm / gear reduction<br />then prop shaft torque must be measured: hp in = prop shaft rpm x prop shaft torque (ft.lbs.) / 5250<br /><br />Example: A boat powered by 120 hp outboard with 2.0:1 gear reduction, runs 47.5 mph @ 5500 rpm. With sophisticated equipment, measured prop shaft torque is 235 ft.lbs. and measured prop thrust @ 47.5 mph is 750 lbs. <br /><br />Prop shaft rpm equals: 5500 / 2 = 2750 rpm<br />Hp Out equals: 47.5 x 750 / 375 = 95 hp<br />Hp In equals: 2750 x 235 / 5250 = 123.09 hp<br />Propeller Efficiency equals: 95 / 123.09 x 100 = 77.17%<br /><br />It’s not common for prop slip or speed calculations to show zero or negative slip percentages. Occasionally an application engineer encounters it. Here’s why it occurs: In the performance reports discussed, the application engineers used Bombardier SST propellers. These props (part number 176***) which are marketed as a “swept blade design” were developed specifically for the Eagle V4 90/115hp. Since the current V4 prop line fit’s all V4 engines (including the old cross-flow), the three cylinder carbureted engines (both the old 49 cu.in. & the 56 cu.in.), the commercial in-line engines and our new E-TEC engines, they may be somewhat a compromise in some applications. In the case of the E-TEC performance reports, the hp & torque curves used in the advance coefficient (which was for the Eagle V4) was not actually reached for the particular props used in this test. Remember: Too much blade area or diameter will lower slip, but also lowers propeller efficiency, resulting in reduced performance. The props could potentially be brought back into their design limits by shaving some blade thickness or perhaps some diameter. If they were brought back to the 10% slip range (using the conventional prop slip calculation method), the operator may actually experience some improvement in performance. If this boat test had been conducted with a 75 hp V4, the “slip %” would be expected to be within the 10 to 6% range. Reviewing several V4 performance reports in which the 176*** props were used, substantiates this conclusion.<br /><br />Bear in mind, for the recreational marine industry, there is no industry standard for measuring pitch. Although there are some broad guidelines, the method for measuring propeller pitch varies from manufacturer to manufacturer and is probably an exercise in futility in all but the most sophisticated of propeller shops.<br /><br />The pitch number stamped on the hub (of BRP props) is what the engineering department dictates. Pitch changes constantly across the face of the propeller blade and we measure pitch at numerous points and at different radii from the center of the prop shaft, using advanced computer-aided equipment. We do not consider cupping, nor do we average all our measurements into the pitch designated on the hub. Loosely speaking, it’s an approximation of the performance you might expect to see with other propeller lines.<br /><br />Regarding the 40/50 E-TEC gearcase, it is the same gearcase used on the commercial in-line engines. By using the 2.67:1 gear ratio we are able to use the V4 line of propellers and although the 40/50 E-TEC does not have the displacement of the bigger (V4) engines, the stall speed with a large prop is perfect match for the 40/50 E-TEC power band and is an excellent choice for large pontoon boats or other applications where high thrust is desired. This is a very robust gearcase, failures are very few and even farther apart. It has exactly the attributes we want for E-TEC.
Forktail
Ensign
Re: E-TEC Performance Report - the whole story
We've already discussed this in detail. The bottom line is that the pitch stamped on the Bombardier prop was not representative of its actual pitch. It was off considerably, yet used in a comparison. <br /><br />Also, the data provided here by an E-Tec dealer (and defended by you and other dealers as legitimate) was proven to be wrong. This was evidenced by the actual performance reports. <br /><br />The "prop formula math" brought out these inconsistencies.<br /><br />
Is this what JB or another moderator told you? Or are you taking jabs in the dark?<br /><br />There is no rule here requiring that you like everyone's personality or attitude. One poster's attitude does not cause an entire thread to be deleted. One member's post can easily be edited or removed by a moderator if it is distasteful.<br /><br />Seahorse, it is clear that you did not like the outcome of the E-Tec discussion. I suspect it is because you are a dealer representative. But it is unclear why you continue to beat a dead horse with futility, and take shots at the barer of bad news.<br /><br />I think you should move on.
Trent
Learn a few things every day....Thanks Seahorse!<br />God only knows what I forgot..Since my mind is full.
walleyehed
Forktail....ever hear the song: "what if G0D was one of us"????? If not, maybe you better listen in.....Hint, Hint.<br />Now...Lay off the CRAP, and let's see how the darn things work!
sloopy
Forktail,<br />DId you go to college and become an engineer, graduate then work for a fortune 500 company? Don't you realize that these guys know more about outboards, engines, props, fluid dynamics and hydrodynamics then you do? It would not surprise me if the engineers send each other your emails as forwarded homur. So please stop arguing with the results.<br /><br />Did not know My spellchecker would miss that.
Forktail
Ensign
Trent, the Bombardier letter shouldn't be new information to you. I originally posted the results of that information, and you commented on it then. Your comments about that information (which included name calling) were...<br /><br />"I will take Johns word over some bimbo at Bombardier that just looks at the pamphlets."<br /><br />Recall that, after much argument by several dealers here (including John), I proved that the performance data posted by John was wrong. The dealers here didn't take that very well, and they are desperately trying to make me out as someone more than just the barer of bad news.<br /><br />
walleyehed, I'm not sure what "CRAP" you are referring to. The letter from Bombardier has been posted and deleted before. Threads relating to its discussion have been locked or deleted. Seahorse knows this, but posted it again anyway, along with snide, baiting comments about another member's attitude. It is obvious where the "CRAP" is coming from.<br /><br />If you recall, I was the one who originally suggested we lay the E-TEC hype aside and "see how the darn things work". I have never talked down the E-TEC.<br /><br />
Sloopy, It appears your perception of an engineer is a little off. But I understand that education and intelligence can be intimidating to those less fortunate. Hopefully your comment was all in fun and not an attack on my profession, which I earned with sweat and blood. <br /><br />
I would hope so. But it doesn't appear to be that way. It seems to be more of an E-TEC sales-pitch theme. I was the one that realized the data posted by them was wrong. I was the one answering their question and getting into the technical end of things. And I was the one that had to clear up much misconception about gearing, propping, etc. I was the one who found the problem with the data. So shoot me...right? <br /><br />
It would not surprise me if the engineers send each other your emails as forwarded hummer.
I don't e-mail anyone. And "hummer" is spelled "humor".<br /><br />
The results have turned out exactly as I predicted from the start of all this. The data was incorrect, and the propping pitch given by Bombardier is not representative of actual pitch. Others here are having trouble with that, so they have decided to attack the barer of bad news. Now we can add you to the list.<br /><br />Talk me down all you want guys, I'll never be ashamed of finding a problem with the E-TEC data, which was boasted about so brashly. And I'll never be ashamed of bringing out good technical discussion and passing on knowledge. Finally, I'll never be ashamed of the truth.<br /><br />BTW, all of your posts have absolutely nothing to do with discussing outboards. Go figure.
JB
This is the fourth thread on this subject. Like the other three, it has turned into a quote and contradict contest with rising tempers.<br /><br />It is about ego, trivia and semantics, and reveals little of value to boaters.<br /><br />Settle down, gentlemen, or we will need to lock this one, too.
sloopy
What problem? Sea horse had the company check over there data to prove to them selfs that it was right in the first place! You actually made the company pay there engineers for work they already did!!! and there was no DIFFERENCE the second time around. Face it fortail, you will not win, you have have no clue what you are arguing about anymore.<br /><br />
LOL!!!...I don't know what to say.....
sloopy
It's spelled technical not techinical
Forktail
Ensign
JB, I agree that the initial post here by seahorse did nothing but drag out old skeletons. Given the history on this topic, his comments about another member's attitude and the math not jiving were provocative, evoking, and baiting.<br /><br />Trent, the problem with your comment (which is now deleted) is that in the case where I posted the same information, you claimed it was from a "Bimbo" and out of "pamphlets". Yet when your buddy seahorse posts it, it's a big thankful learning experience. Go figure.<br /><br />Sloopy, apparently you've missed much.<br /><br />
What problem?
The problem was performance report data posted by an E-TEC dealer showing how "remarkable" the E-TEC was. I simply pointed out problems with the data, showing that it was impossible to achieve the boasted performance based on that data. Several dealers (or dealer representatives) like seahorse, Backfire, John from Illinois, etc., defended that data to the bone. Their excuses lead that discussion into many arguments and much misinformation. <br /><br />No big deal, but the bottom line was that when Bombardier provided the actual data to me, the truth came out. The data posted here was in fact a fraud, and the nay-sayers mocking me were wrong. However, no one has stepped up and acknowledged their blooper. Instead, threads like these continue as some form of vindication.<br /><br />
I was the one who originally suspected and found a problem with the data posted here, not seahorse. It was me who initiated contact with Bombardier in order to get the correct data and an explanation from them, not seahorse. Many of us received the exact same information shown here from Bombardier (please re-read Bombardier's first sentence). In fact, Bombardier even provided me with the actual performance reports.<br /><br />
No. John from Illinois did that when he posted the wrong information (or manipulated it). I simply pointed out the problem and got to the truth.<br /><br />Again SLOOPY, as JB has said the posts in this thread have nothing to do with outboards and offer little value to boaters.
Mettaree
It sounds like a couple of people need their diapers changed, take a time out and catch a quick nap. Let the dust settle. PLEASE!!!!!
Walt T
I would like to point out that Bombardier admitted that their pitch number is vague and actual pitch could have been completely different than what is printed or stamped.<br /><br />This was Forktails point entirely. <br /><br />Like it or not he was correct.<br /><br />There may be some argument over how pitch changes over the face of the blade, but that's really irrelevant.
seahorse5
Weren't you the one, Forktail, that complained that you could not get through to Bombardier and I furnished the phone numbers for you? My question to Bombardier was there for over a week before your request arrived. We all did receive the same form letter from them since it had to be "reviewed" by several departments before issuance.<br /><br />I have other questions in the works, but the 2 weeks of holidays, and my being out of town last week, haven't let me contact them to check the status. Again, I'll post the full response that I receive to share with this group.
rodbolt
hello<br /> I suspect bomb was "cooking" the data slightly. the average joe boater doesnt known or care about the subtle differences. it happened with cars in the 60's and 70's with cams and horse powers which is why so many motors had such wild cams yet still had power brakes. that is why the lift and duration specs now start at .05". there has to be a standard. jonny rudes were flash rated on a dyno for some years and suzuki got busted for under rating and merc would rate them at 4600 and turn them 6000. I am thinking the pitch on the test props are progressive and variable acrossed the blade face and the numbers stamped are an average. if your average is cooked to one side or the other then you can have a 17P that will act like another brands 16 or 18P. its all pretty much irrelevant cause I just want to see a motor that can fish here in the pond three times a week burning 80 to 90 gallons of gas a weekend and have absolutly no maint,period, for 3 years. this I gotta see. or a motor that can burn 30 gallons in three years and still have 10 gallons of the original fuel left if it lives at the beginning of the 4th season. this will be a real life test of the outrageouis claims Bomb is making. call any sales dept and they will tell you how this may be the last outboard you will ever own and if upgraded will serve dinner, scale fish and wash dishes.<br /> all I ever said was after the fisrt second and third DFI debacle I will hold off on recommending the forth to my customers.<br /> good luck and keep posting
BRIAN03
Good Job Seahorse nice post.
walleyehed
Rodbolt, I don't know what you'd call it for sure, but the boys up west of me with the 50 and 75 said the oil tank on the 50 wasn't big enough, and they wouldn't let it go more than 3 days before adding oil. Granted, they were running Ficht Ram at a rate of 50:1, and the engine was built to be oiled at 100:1 with synthetic, and if thats the case, thats 60-75hrs of run-time. If what they told me is true of fuel burn, the 75 is more likely to burn 15-18gal. in a HARD weekend, run WOT alot.<br />Most all props have been progressive pitch since the mid 70's, and I'm not sure where this debate came into sight...It's a performance issue, and it's been around a long time.
Forktail
Ensign
Seahorse, I have no idea why you would want to argue this stupid issue with me, but before you flatter yourself and I answer your question, you better review that thread.... :eek: <br /><br />
Where do you come up with this stuff? Who said I "could not get through to Bombardier"? :confused: <br /><br />The issue was about trying to contact someone who could explain the (erroneous) data. "Getting through" or needing a "phone number" was never an issue. Getting knowledgeable help from Bombardier was. As evidenced by that thread here....<br /><br />By Forktail - "...my attempts to get this data explained have been futile."<br /><br />Seahorse, you provided the basic phone number (which anyone has access to) on 12-09-03, after I had already used it, and after members like John and M13 posted it! This is evidenced in that thread here....<br /><br />By seahorse 12-09–03 - "The main number is 847-689-6200 and customer service is 847-689-7090."<br /><br />By Forktail 11-24-03 - "I've also learned that...The 90 hp 25" shaft has a V-6 gearcase." - A result of contacting Bombardier 11-22-03. <br /><br />By Forktail 11-26-03 - "I've requested the 0-6000 rpm engine torque specs on the 2.67 gear ratio E-Tech outboards from Bombardier."<br /><br />By John from Illinois 11-24-03 - "Call them yourself...847-689-7090."<br /><br />By M13 12-05-03 - "If anyone needs...they should call Bombardier's Consumer Support Line at 847-689-7090."<br /><br />Furthermore, out of curiosity I asked you twice who you contacted at Bombardier. As evidenced here....<br /><br />By Forktail - "Great. Exactly who did you contact (name and number)?"<br /><br />By Forktail - "One more time...exactly who did you contact (name and number)?"<br /><br />You did not answer. <br /><br />
I had asked Bombardier questions about the CARB rating, gear ratios, gear cases, available props, etc., etc., long before you requested anything. We had been corresponding for quite some time.<br /><br />I posted a communication from Bombardier in that thread on 11-24-03, as evidenced here....<br /><br />"All of the E-TEC models, with the exception of the 25"- 90 hp offshore model (90 DPXSR) will use any of our V4 style props. The 90 DPXSR will use any of the standard rotation V6 style props due to a larger gearcase used on that model. - Boats and Outboard Engines Division"<br /><br />seahorse, you did not mention that you contacted Bombardier until 12-07-03. Even a "week before" would be way after 11-24-03, when the data was posted, and when I contacted Bombardier. As evidenced here...<br /><br />By seahorse 12-07-03 - "I did contact someone at Bombardier and they will check into the data."<br /><br />You were late seahorse. <br /><br />
Unlike you, I also received the actual performance reports, which were initially available only at Bombardier's dealer-only web site. I also received other letters about other things that I requested on this issue. The information I requested was not the same as yours, nor was it requested after you.<br /><br />You have no idea when my "request arrived" or what communication I had with Bombardier. I'm not sure how or why Bombardier would divulge my requests to you. :rolleyes: <br /><br />I was the first one here to report on the findings. Just like I was the one who originally found the errors. You've done nothing but nip at my heals the whole way, providing little information other than media clips. <br /><br />But if you want the credit and insist on shooting the messenger, then fine. It really doesn't matter to me. <br /><br />However, I feel you owe me an apology for the misrepresentation.
seahorse5
Like the tides, you are predictable.<br /><br />By the way, I was notified when your inquiry went thru the "system" at Bombardier, and you are making assumptions that are incorrect.
