E-tec 25 suddenly stop
nnyerges
E-TEC 25 SUDDENLY STOP
A few months ago I bought a E-tec 25HP (manual start). At first time, I tried it at home and it worked perfectly: start at first rope pull, check the gear box forward and reverse and everything was perfect.
Last week, I install the motor on my dinghy and give it at try on the water. Start at first rope pull and undertook a test drive. Running at middle speed and about 5 minutes later, the ENGINE SUDDENLY STOP.
At first I thought he had hit a wood or something, but no. Simply turn off. We check oil, fuel, alarm LED?s and everything was ok. Also, the propeller was free.
When trying to turn it back on pulling the starter rope was tied (the flywheel was block, like when you try to start the engine with the gear in forward (it was in neutral). We try about 10 times until suddenly loosened the flywheel. We try start the motor again a couple times and the engine start. All alarm LED?s was ok.
We put forward and started traveling back to the dock, when suddenly, the engine suddenly stops again. This time, we spend more that ? and hour to try to start the engine, without success.
Any idea?
Optional Information:
Make (of engine): EVINRUDE
Model (of engine): E-TEC E25DRLIS
Year: 2010
Horsepower: 25
Already Tried:
- We review the entire flywheel mechanism
boobie
Re: E-tec 25 suddenly stop
Was the flywheel seized when it quit ?? Two things. Either the lube system is not working on the mtr or the gear case is locking up.
nwcove
.......or your alarm is not working and neither is your impeller.
nyx2k
overheating and will loosen off when cools down
nnyerges
This weekend I disarms the flywheel looking for any damage (nothing, all ok). I pull out the spark plugs and I pull the rope (all ok, the engine turns without any problem). I found some humidity in the spark plugs mixed with oil. I returned to place the spark plugs and I proved the compression and everything was well. I start the engine for a while and manually shut off ( I do not like the fact that I found water in both cylinders). Or it is the broken seal, a bad gasket or the block is cracked.
It is a new motor without at least a 1/2hour of use. It would have to take the motor to Envinrude, but the problem is in which that model of motor came with manual control lever which disarmament to adapt it to a central control, and to return it to arm so that they prove it, is a headache.
Note: The oil reservoir was cracked but still half a tank of oil inside.
Some suggestion?
