E/Fisherman I.d. for me? Thanks!
ace99
The id plate is gone. Motor was my fathers.
E Fisherman, I think 6hp. Wanting to know for sure and the year approx.
The round plate on the powerhead is stamped 131 RPH
I put photos at:
http:/s653.photobucket.com/albums/uu253/b91701/?newest=1
Also - it has a shaft extension(?) above the lower unit.
Is it possible to remove this and convert to a short shaft?
It looks like it is easy to remove,maybe originally was a long shaft kit.
Would I have parts to buy other than gasket and lube?
Thanks,
Bill
Vic.S
Re: E/Fisherman I.d. for me? Thanks!
Looks like a model from a round late 60s early 70s
You could shorten it but you would need the to shorten the water tube, fit the standard length shift rod and the standard drive shaft. A drive shaft looks like about $270
don't see a shift lever though. Looks more like a 5hp In which case drive shaft only about $80
F_R
Honorary Supreme Mariner
You have a 1971 six horsepower. Model 6102 if it is a short shaft, 6103 if long shaft (as it came from the factory--it could have been kitted). RPH stands for Replacement Powerhead. It isn't the original. The model & serial tag is supposed to be on the port stern bracket.
