Re: dyno
Randy is right, Kannuki. All it takes is a 25 dollar gauge. And this same gauge will werk on your car, lawnmower, weedeater, Hp washer, and anything else powered by gas.<br />You can do a compression test whenever you change the plugs,and kill two birdz with one rock.<br />Dynos are rare, and won't tell you much.<br />Compression test, spark test, primer bulb test, and you'll probably find the problem.
