Dumb newbie question
jtl_90
I was riding with a friend in his 16' flat bottom alum. john boat with a 40 horse merc outboard. The boat and motor run great up until 3/4 throttle. From 3/4 to wot the rpms go up but no increase in speed. Is this normal for this set up? I have no experience with outboards so I am no help to my friend.
The motor has a 15" 4 blade s.s. prop.
Any help or a direction to go would be great because it's bugging my friend to death!
BIGcarpy50
Re: Dumb newbie question
could possibly be a slipping prop, carb issues, coils, or stator. check the HUB on the prop, and check the electronics.
reelfishin
Is it truly increasing in RPM's or just getting louder and bogging down?
I'd say maybe it's dropping a cylinder or has too big or too steep a prop pitch.
40 hp on a jon boat should all but fly. I tried a 50 hp on a 17' once and could never think about wide open throttle and needed to keep some ballast weight in the bow.
Is the motor the right length for the transom?
jtl_90
The motor seems to run very well. It does not have a miss to it or seem to be doing anything else to make me think there would be a problem with it running. So maybe the 15" 4 blade is to much? There are always atleast 2 peaple onboard with fishing gear and/or hunting gear so the motor needs to be able to work.
tashasdaddy
also could be trimmed too high, and prop starting to blowing out. (loose bite)
JB
Sounds like prop ventilation to me, but could also be cavitation.
I suspect that fancy, 4 blade, prop is entirely unsuitable for the application and/or the outboard is not ideally rigged.
Let's put this in the Prop Forum and see what the prop gurus think.
jtl_90
Sorry if I posted in wrong forum. I am trying to learn as much about boats and everything about boats as I can. I am getting ready for my 2nd season as a boat owner,so I figure if I can help my buddy out,it will just give me more knowledge for the future.
Thanks for the help so far!
reelfishin
The prop on my 40 hp, which was last on a small glass boat, about 600lbs in weight, is only about 10" in diameter and maybe a 13 pitch or so.
I don't think I could even get a 15" on that motor?
Try your specs on one of the online prop selectors and see what it gives you.
