Duel gas/air line connectors
bigamps
I have a 54 johnson 5.5hp with the duel gas/air fuel lines and both connectors for lines have either been crushed or broken over time. Does anyone know if and where you can buy these dual line connectors?
D
DJ
Guest
Re: Duel gas/air line connectors
A Johnson/Evinrude dealer will probably have them.<br /><br />These guys definetely will. If you buy used, get rebuild kits (o'rings) for them.<br /><br />www.twincityoutboard.com
Paul Moir
vintageoutboard.com has them new, but once you see the price you'll be looking for used. There's a couple on ebay. Search for:<br />("double line", pressure, "dual line", pressurized) (omc, johnson, evinrude)<br />Also, you could try finding a used one from an online or local outboard junkyard. tcoutboard.com marinepartsoutlet.com laingsoutboards.com have used parts.<br /><br />Might also consider converting to a single-line tank if your handy with tools and already have a single-line tank. I think it's cheaper to fix what you've got though.
bigamps
thanks for the suggestions. i had bought repair kits for both connections and it wasn't till i began to remove old o-ring and bushing that i realized how messed up and ruined the old connectors were.
