Ducted vs. non-ducted
kameika
Alright, here's a question. I have worked on many engines, and am even getting "okay" at working on my OMC Seadrive (2.7 Liter 1987 model, manufactured in 1986.) I am told this model is a "Looper."<br /><br />What's the difference between a "Ducted" and "Non Ducted" OMC/Johnson/ER engine?<br /><br />Many thanks!<br />Ken Ameika<br />Red Bank, NJ
Dhadley
Re: Ducted vs. non-ducted
The "ducted" Sea Drives has a hose that went into the boat to pick up the air. Yes, your 2.7 is a samll bore (3.500" -- std bore) looper. In 1988 they went to a 3 liter V6 that was 3.685 std bore.<br /><br />Good luck!
kameika
It's funny you should mention that 3.0L variety.. Could you confirm something:<br /><br />I am told the same power head block for the 2.7L was used for the 3.0L; but with the cylinder over-bored. <br /><br />It was said the thinner cylinder walls caused troubles on the 3.0L Sea Drive.<br /><br />I'm asking because I re-told this story to another fellow, who was considering a 1990(?) Johnson "Looper." Was I telling the truth?<br /><br />Thank you..<br />Ken
Dhadley
Yes the 2.7 can be bored to 3.0, no problem. A true 3.0 liter block does have slightly different port timing but that can be altered also. In 1991 there was a change in the casting that was never taken advantage of until 1993 when the closed deck loopers came out. <br /><br />A 2.7 bored to 3.0 should not have any cooling issues nor combustion temp issues as long as the heads are upgraded to the 3.0 style. 2.7 heads on a 3.0 is a real easy way to increase power. To the point that you need to run a higher octane fuel to keep it alive. <br /><br />The 3.0 liter motors are very strong and are very reliable. A lot of 2.7's were changed to 3.0's under warranty in 1988 and after. If a 2.7 was under warranty and required replacing, many times a 3.0 was used and the owner never knew. There's nothing wrong with the 2.7, the factory just upgraded to a 3.0 block.<br /><br />Hope that helps!
