dual prop
gobbler boat
I have owned a single prop I/O for 12 years. New boat has 8.1 Volvo w/ dual prop. Is it normal to have about an 1/8 inch of play on the two props or should they be tight-tight? I can bump the back prop back and forth about an 1/8 of an inch without the forward prop moving?
bruceb58
Re: dual prop
Just went out and tried mine. Doesn't move at all.
Don S
Re: dual prop
There shouldn't be any movement at all. The prop should be tight, an the shaft itself should have a preload, no movement at all.
Jeepster04
Re: dual prop
If you're talking about rotational play between the two props then yes, that's very normal. Just a little slack in the gears. Any side to side play or play on the shaft itself is NOT normal.
