Dual Pro-Pro Xtra II "On the run" charger
lrice01
Greetings good people!<br /><br />I'm interested in this Pro Xtra II "on the run" charger. My inquiries to Dual Pro have been unanswered.<br /><br />Does anyone have any experience with this unit and if so what are your thoughts??<br /><br />Thanks....................Lee
Silvertip
Re: Dual Pro-Pro Xtra II "On the run" charger
If you already have an on-board charger, you could use a simple $30.00 battery switch to do what you want to do. If not, then this unit will give you the capability to charge the troller battery from the engine. The start battery of course already charges from the engine. If you run short distances between fishing holes, this unit will not be of much help as very little re-charge will happen in a short distance.
