Dual Isolator Battery Bank Pro Required
POCO001
Hi All,
Anyone who reads this first off thank you!... I appreciate any insight you can provide.
I am trying to implement a dual battery bank wired in parallel for the "house" along w/ an isolated single starting battery.
I have drawn a schematic which I am not sure is correct. I am unaware what lines require fuses & if so what rating.
Also you will see a switch which would provide emergancy combine to override ACR.
Heaps of appreciation to anyone who finds the time to assist.
Thx.
-Adam
ATTACH=CONFIG]166986[/ATTACH]
JB
Re: Dual Isolator Battery Bank Pro Required
Howdy.
Welcome to iboats. :)
This really fits the Electrics Forum, Adam. You will get better response there.
I will move this for you.
Ayuh,.... Welcome Aboard,.... Let me see if I can find ya an "Expert", or 2...
edit;... Ok,.... Glad to see ya JB,... I'll let you move this,.... ;)
yep the boat is upside down or is that just the drawing.
looks good just doesnt sense that you have a a-b-dual switch that does nothing. if you have a battery fail the acr will open and protect the good battery/batteries having a bypass switch will remove the protection. another way to look at it is connecting a fully charged battery to a flat battery while trying to start a motor. use the switch for what it was designed for. if the starting battery is dead switch to b and allow the house batterys to start the boat only if all batteries are real low do you switch to dual in the hope that theres enoght ampage between all 3 to get the boat started. dual is a last option. keep it stupied simple and trust the equipment you install.
