dual I/o power trim and tilt master button
Mercperk
I need to figure out how to DIY wire the master trim button with diodes.
I have twin 3.0l mercs with I/o , bought a seastar/domestic standard remote control, specifically the chx8242p, came with 4 buttons not counting the master trim on the handle. I'm assuming the 2 extra per side are to individually control the trim and tilt. Also came with 3 little colored wire diode packs. Green, blue and red. Each with one colored wire sort of off to one side and to the other 4 colored wires.
The instructions that came with were to say the least, lacking.
So what do y'all think? Anybody got an idea how to do this?
I'm probably just looking at it backwards somehow. The way I always thought about it was that only the master trim button wires get a diode but the more I think about that it doesn't make sense for where you're pulling 12 volts from. Jeez I think I confused myself and for the life of me all I can find on internet are diagrams of old school dual setups with a big ole module
Ayuh,.... Might be lacking, but what is said,..??..??
General trim wirin' is red power, blue sky up, 'n grass green down,....
Mercperk
B
But then when you have 2 I/o and you have a master trim button to control them both. How is this accomplished while keeping the engine circuits separate?
Mercperk
B
And while keeping the trim pumps using their respective engines battery?
Mercperk
Oh here the instructions
Mercperk
Seastar remote controls do not have a purple white so that's one area I'm confused about
So you're saying to just keep em separated?.... Yeah you're right.... Well I over-thought that just a bit...
Thank you
Exactly
Keep them separate
And read the gauges
One drive will always raise at a different rate than the other
