Dual exhaust: what say you?
simple
What are people's opinion about dual exhaust on half ton, 4 wheel drive trucks?
brine
Re: Dual exhaust: what say you?
You will see a few extra Hp. :) :cool:
heycods
keep it quite, I treasure my sleep. :)
Ayuh,..........<br /><br />And your Gas Mileage will Drop by 1/2................ :rolleyes:
Kenneth Brown
I like a good ex system but don't get carried away. HUGE tips just mess it all up IMHO.
JB
Non-boating Tech.
simple
Originally posted by Bondo:<br /> Ayuh,..........<br /><br />And your Gas Mileage will Drop by 1/2................ :rolleyes:
Yeah, that's what I thought also, but some people say it will increase a little because I'm getting more flow?
JB
Most are too loud.<br /><br />A well designed system will improve both power and mileage. Most systems are not engineered at all and decrease both, as well as making too much racket.<br /><br />I have a professionally engineered all stainless cat-back dual system on my V8 ML. Small improvement in mpg, noticable improvement in torque. Nice sound. . . you can hear it but it doesn't intrude. More of a humm than a roar.
JRJ
Does an increase in exaust pipe diameter help a gas engine like it does a Diesel? Air intake improvment?
JB
Not necessarily, JRJ, and not necessarily on a Diesel, either.<br /><br />An optimum exhaust system acts like the pipe on a pulse jet, alternating positive and negative back pressure at the exhaust valves. At the "tuned" rpm the negative pressure occurs when the exhaust valves open, sucking the exhaust out of the cylinder. That is what is called a "tuned" exhaust system.<br /><br />Catalytic converters and mufflers complicate the engineering immensely, so a variety of acoustic techniques are used to get as near as possible for a broad range of rpm.<br /><br />Simply going to a larger pipe and low restriction (LOUD) mufflers can just as easily decrease torque and mileage as improve them.
treedancer
If your familiar with electronics its similar to a resonant circuit
Originally posted by treedancer:<br /> If your familiar with electronics its similar to a resonant circuit
Thats a short way to say what JB did. :) <br />With RF it works both on transmitt and recieve! :D <br />Same with exhaust! :eek: <br />Didn't know that until about 15 years ago!<br />Link
20/20
A properly done dual exhuast will be an improvement!
Ron G
Im going back with true duals this week on my 1500,hopefully,thinking flowmaster 50 with 3" pipe.
JRJ
It seems to me on a gas rig, you would start with tuned headers if performance is what you're after. As for Diesel pickups, 4" and 5" exhaust and after-market air filter systems are the recommended beginning for adding hp.
phatmanmike
i have custom duals on my 1984 gmc 1500 shortbed<br /><br />350 v8 headers, 2.5" pips with " H " pipe and dual flowmaster 40 series. not loud, just a low rumble, but i can tell a huge difference in how it drives....much better
bandit86
Banned
you only need so much exhaust n a car, a dual 2 1/4 inch is plenty for most. roughly same area as a single 3"<br /><br />I'm thinking of duals for my 3.9L range rover just for kicks
craze1cars
Exhuast upgrades are overrated on newer engines...carb'd engines were a different story, but today's motors don't usually benefit as much, but I agree they might benefit a little bit. A true straight-out dual is usually not the best system. You want some type of tuned crossover that mixes the sides AT THE RIGHT LOCATION to take advantage of scavenging effects. For this very reason, you'll find that the most expensive well-tuned systems that produce the best flow are generally NOT dual exhaust...they come out at one pipe. Usually duals are a cosmetic thing much more than a performance benefit for those who like to red-neck-ify their rides. Nothing wrong with that if you like the look, but don't necessarily expect any performance improvement. Pipe diameter is also critical...too small AND too big a diameter will detract from flow characteristics and necessary backpressure. Every motor flows different and you need to know the flow characteristics of your motor to choose the correct system.<br /><br />For a modern engine (most anything with fuel injection), you'll usually get a WHOLE lot more bang for you buck if you invest the cash in a performance chip or computer re-programmer and keep your stock exhaust. <br /><br />But if you need a new exhaust anyway due to rust, etc, it's a good time to upgrade to something better. You get what you pay for...as a general rule the more expensive tuned systems ($500 and up) have dyno testing, flow testing, and professional design behind them. The cheaper hodge-podge ones in the $200 range will just make the truck loud, be difficult to install properly, possibly cost you performance, and they'll come loose, rust, and/or fall off in a year or two.
Ron G
So true duals on my 95 gmc 1500 with a 305 is not a good idea??
