DT9.9C won't run without full choke
pnadeau
engine has been stored for several years. would only start using starting fluid. cleaned carb, now starts with gas, but only with full choke and quits as soon as you push the choke in. when cleaning carb, main jet was stuck, assume it screws all the way in, but have no tec manual to show this. Any suggestions on where to go from here? Also, can someone give directions on how to remove the tiller handle? thanks
deejaycee_2000
Re: DT9.9C won't run without full choke
Why would you wanto remove the tiller? Your carb is still dirty .... you need to take it apart completely and soak over night in carb cleaner and then blow out with compressed air .... yes the jet must me in all the way but to soft stop don't force it ..... the air/fuel mix screw (one with spring) must be turned 1 1/2 turns outwards from soft stop ...
pnadeau
I have removed the carbureter soaked it overnight, took it apart and soaked it again, blew it out with air. reassembled it, and adjusted idle screw. I took the fuel pump apart, soaked it, reassembled it. I put in a new inline fuel filter. I re-installed this assembly into the motor and it still only starts with a full choke, and dies as soon as you push in the choke. The matter of the tiller handle is a seperate issue. the handle has been broken and since it is cast aluminum I can't find any way to fix it. in order to put a new one on I will have to first get the old one off.
deejaycee_2000
Do you have a remote setup on there? Did you check your float level height?
