DT85 stalles when put in gear
jimfrazer
Have tried litterally everything and read every forum. Still stalls in gear. Idles smooth and runs great at high speed. dies when put in gear. Can the low idle condencer coil be the problem?
pmassey31545
Well, I can't help you with your problem, but I can give you a bump. I am also having a similar issue. I can get my '82 DT85 to start-no problem. Keeping it running idle is my issue. But I can get it going, sort of, by revving up then throwing in gear (not good I know). But it still dies under any forward load. Now in reverse it is fine and will tach up nicely.
I have cleaned the carbs-and they are CLEAN! Checked fuel pump. Replaced fuel bulb. Air fuel screws. Cleaned the carbs. New gas. Ran carb cleaner through. Changed the plugs. Set the floats (best I know how from other member suggestions). Did I mention I cleaned the carbs???
OK. So my issue is somewhat the same. I can put it on ears and 'Make it' run. I have my kid start it while I stand by. Then control it with the spark advance lever and choke. It runs smooth at 2200-2500 RPMs (again, I know, not good on ears). But if I release the advance and return the control lever to idle, it will cut out. SO I was hoping for some ideas before I spend big money trying to get someone to fix this thing.
