DT85 Rebuild
ollylogan
I have a 1985 DT85 Suzuki im planning to rebuild.
Has been run with-out oil so major damage to the short-block. My plan is to strip and replace damaged parts or replace block alltogether.
Im at the stage of pulling the block off the Engine holder, taken all four studds underneath plus another two and a small one from the back , the block is now loose but still wont free from the gear-box.
Can anyone tell me what im missing -out on removing the block off ?
I was also wondering how i remove the flywheel.
99yam40
Re: DT85 Rebuild
did you disconnect the shift shaft?
If so then splined drive shaft maybe rusted into the crank
ollylogan
Re: DT85 Rebuild
Yes i did disconnect it.. So it seems i have done everything right ?
Ldavidgrover
Re: DT85 Rebuild
how about a big rubber mallot. You did drop the lower unit?
ollylogan
Re: DT85 Rebuild
Did some research, no i havent dropped the lower -unit. Guy at the marine shop didnt mention that! I will remove that next before i give the power-head another try..
