FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Anyone have the factory piston to cylinder clearance specs.for a 1983 Suzuki DT85. Clymer's manual states .112"-.127" , this is got to be wrong.
Thanks
I'll check my Clymer Yamaha manual, clearances should be very similar. I'm guessing a clearance in the .004" to .008" range between the piston and the bore. I'll get back with you after I check it out. Good Luck!
