Howard Sterndrive
Thread starter- Joined
- Nov 5, 2008
- 4,603
I have 2008 4.3 Dry Joint manifolds on my 1985 MR185 (229 V6 Chevrolet)
I had to use the old cold manifold style thermostat housing (has to do with alternator mounting) so I a plugged the riser feed port and have just 1 hose to each manifold feeding the bottom.
I see my temp gauge climbing gradually at WOT... past 170..sneaking past 180..so I back off and it cools down again.
The risers are about 160F when I drop off plane and run back and check... after a minute or five at idle they are cool to the touch.
I see a 27-864547A02 gasket for "FULL FLOW" that has 2 wide open holes at the riser joint for water flow. The current ones have 1 wide open and 1 restricted.
I guess it is worth a try to use the full flow style.... thoughts?
