Re: Drum surge Brakes to electric brakes
This posting is going in different directions. Let's get back to the question at hand: Should he switch to electric disc type brakes on his boat trailer since he already has a brake controller in his truck.
I've made every mistake with trailers, including almost jackknifing (twice,) running with bent axles eating up the tires, running big travel trailer 400 miles w/o the electric brakes working. I also went into a ditch with a skidsteer loader on a trailer. The sight of a trailer swaying 45 degrees left and 45 degrees right is frightening.
On boats, I prefer run surge drum brakes to keep things simple. Surge brakes do not activate much unless they're really needed. I forget to unplug electric brakes prior to submerging the trailer in water--fresh or saltwater. But, all heavier tandem trailers must use brakes on all 4 wheels or they're not really safe.
Now, let's talk about trailer tires. Car tires don't cut it on any substantial trailer, as the sidewalls are just too light. If you're pulling more than a few miles to the lake, invest in a set of real E rated trailer tires. And, run them at the maximum inflation rating. 15" and 16" trailer tires are expensive, but they're cheap insurance. Last law of towing: Don't run any trailer tire if it's over 5 years old due to dry rot and ultraviolet light deteriorating the rubber. I don't cherish changing a trailer tire on an interstate highway in the middle of the night--done that.
I'm an RV'er, and this is a subject that is discussed almost daily in Recreational Vehicle/Camping trailer online forums. If you Google trailers, there's a lot of advice on the internet about trailers, brakes and tires.
