Driver coil 1976 35 hp Evinrude
mrcrw009
I have no spark at all on either cylinder and have checked everything the book says and it looks ok as far as a regular ohm meter will tell me. I did notice that the driver coil under the flywheel the center coil is shorted to the other posts that are beside it that the screws go through. That does not seem correct to me. If anyone could help me I would be much appreciative.
mrcrw009
Re: Driver coil 1976 35 hp Evinrude
oh and i forgot to mention that the wires on the coil are disconnected so no they are not grounding throughout the points
