Drive Shaft Wont Spin
thetailwind
Hello, I had been doing some work on my 2001 Johnson 6.0 with the lower gearcase. The lower gearcase had been sitting inside without any oil in it for a few months after I had replaced the water pump and seals. Today I reassembled it, put fresh lube in it and pulled it to start. The motor would not turn. I have done the following:
1) Taken the pull start off to check the pull mechanism, it functions properly
2) Removed the spark plugs and checked for piston movement when I spin the flywheel, There is piston movement although limited by whatever is stopping the shaft rotation
3) Spun the prop to verify it was not in gear, it spins in neutral and is in gear in forwards and reverse.
I'm thinking things got a little corroded in the lower gear. I'm hoping the fresh gear oil is penetrating whatever corrosion is down there and will magically fix everything. Is there something else I should be looking for?
thetailwind
Sorry, 2 Stroke.
And for clarification, The prop DOES spin in Neutral, but does NOT in forward or reverse.
Honorary Supreme Mariner
Will the flywheel turn easily when the recoil is off it.?------Will flywheel turn in nuetral , yes or no.?-----Will flywheel turn in forward gear , yes or no ?
thetailwind
Assuming the recoil is the pull start mechanism, no the flywheel does not spin when it is off. The Flywheel does not spin in neutral, forward or reverse.
interalian
Time to take the leg off again to see what's binding. Maybe the impeller is pinched in the housing?
