Drive Shaft Pinion Gear Bravo II
johnbhite
Hello all, I had to replace the drive shaft assembly in my 1996 Bravo II. I took the pinion gear and bearing pack assembly from the old shaft and put it on the new one. I followed the manual for re-assembly and its say's the spacer between the bearings should move freely. My question is, should it still move freely when the proper preload has been set?
