ESGWheel
- Aug 29, 2015
- 263
How I dealt (so far) with dredged VP Fuel Pump Whine. 2005 Larson with a VP 5.0 GXi. New to me in 2015. Nice boat, well cared for, very low hours (less the 250).
My first encounter with the dreaded Fuel Pump Whine (FPW) was in 2017 when I noticed the unusual high pitched noise and started investigating. Using a mechanics stethoscope was not hard to figure out from the high pressure fuel pump and wow was it running hot!
With limited time and a strong desire to not break down during the season, my limited research reviled the aspect of the pump’s internal paint peeling which clogs the High Pressure Pump filter causing the whine and overheating. And that the Fuel Module cannot be rebuilt. So a $1,000 later I had my new OEM VP Fuel Module installed, checked the pressures (all good) and forgot about it. My mistake was not doing enough research.
Fast forward to 2019 and during our Northeastern limited boating season I hear that dreaded whine again. Quick investigation and yep, it was the FPW and the high pressure pump was hot to the touch. Crap. Lots more research this time and man oh man, lots of info about these Carter built pumps and how the ethanol gas dissolves the paint and they can be rebuilt, and, and, and….
Also during this time I was noticing a drop off in fuel mileage. Used to be an average of about 4 MPG and now down to 3 and even less. Note: I have a marine GPS so have accurate distance traveled and a fuel whistle in the vent tube which allows consistently filling the tank to the same level (the whistle is in the vent line and stops whistling when gas hits it). But I did not put 2 and 2 together about the mileage and FPW.
Not wanting to drop another grand only to do it again in a couple of years as well as not risk ending the boating season early, I opted for an aftermarket Fuel Assembly for $180 and started carrying it with all the necessary tools. Also signed up for BoatUS towing service. All cheap insurance and well worth the peace of mind. Boating season continued and in the meantime kept digging on what is the complete answer, if any.
Searching for posts on poor fuel mileage I ran across an excellent post by JohnnyCake of Helsinki, Finland back in 2015 about how he was experiencing poor mileage on his VP 5.0 GXi and traced it abnormally high fuel pressure due to a clogged return screed on the fuel pressure regulator. He even had a link to a VP Bulletin explaining how the screen should be replaced with an E-clip. And the screen was clogged due to dissolving paint!
A check of my pressures and sure enough high side running at 100 PSI vs. should be 50 to 60.
But here we go again with the VP parts so much more than anyone else. Come-on, I know this is a GM motor and not a VP specific design. Who has done the x-referencing? Fortunately many. So in goes a $30 generic regulator (supposedly a GM brand but no evidence of this anywhere on packaging), with screen, and poof, pressure down to 58 PSI and mileage back up to about 4 mpg. And boy oh boy was the other screen clogged with debris, I mean completely caked with crap. Was it paint? No doubt in my mind. E-clip? Not widely available but fortunately found it on eBay and got one to install later.
During some relaxing time on the boat I continued to search for the paint resolution. Ran across a video by Troy Brya from ManCaveMechanic who said he pulls the Fuel Modules apart, cleans out the internal paint, does what else is needed and puts it all back together. Hmmm, seems like the answer to the dreaded FPW and more. Fired off a quick email and sure enough he is still doing it.
In the meantime, got the E-Clip and read about how a BOSCH brand regulator fits in the VP 5.0 (and more) engines. Rather have a branded name so ordered on of those, also for $30. When it arrived I compared it to the VP OEM regulator with a Digital Caliper and was the same. Removed the screen and put on the E-clip, but more on that later.
So the plan is to compete the season, which is coming rapidly, and pull off my $1,000 OEM Fuel Module and send it to Tory of ManCaveMechanic for a rebuild that includes stripping the internal paint. Get it back installed, put in the BOSCH regulator, and then winterize it. The $180 aftermarket Fuel Assembly and ‘GM’ regulator? I’ll hang onto them, just in case. Along with the tow insurance.
I’ll follow up next season with an after action report on how it all played out.
Hope this is useful to someone with a 'new to them' but older boat with similar symptoms.
In the meantime here are some links that may be useful:
Troy Brya from ManCaveMechanic LLC who rebuilds VP Fuel Modules
http://youtu.be/udFyawGJL4I
Post about High Fuel Pressure by JonnyCake of Helsinki, Finland
https://rinkerboats.vanillacommuniti...ulletin-p-23-7
Aftermarket Fuel Module from Amazon (I have not installed this so cannot attest to its compatibility, etc.)
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Aftermarket (GM brand?) Fuel Pressure Regulator from Amazon (it does work and does not leak)
BOSCH brand Fuel Pressure Regulator from Amazon (I have not installed this so cannot attest to its compatibility, etc. but it measures same as OEM)
E-clip (brand unknown due to generic packaging) from eBay (it did install correctly per the VP Bulletin but I have not installed the assembly yet)
https://www.ebay.com/itm/VOLVO-PENTA...72.m2749.l2649
VP E-Clip Bulletin
https://www.dropbox.com/s/i3y1kznhp9btg7g/156%20PB%20P-23-7%20N03%20V01%20Fuel%20Pressure%20Regulator.pdf?dl=0
VP E-Clip Bulletin
