Drains for an AQ 130 and winterization
Hermyboy3000
Hello all!
Where are all the drains for this motor? I can only find one at the oil cooler.
I don't want to go through what I did a couple years ago. I pulled most of the cooling parts off and blew compressed air though it all (what a nightmare).
Also, one more question. I was wondering if running straight antifreeze into the motor after it has warmed up (opened tstat) and letting the water pump suck up a gallon or two until it comes out of my exhaust is sufficient? Is this retarded?
Dakota47
Re: Drains for an AQ 130 and winterization
You have to Drain all the Water out of the Engine & Manifold or you will have a cracked block/Manifold in the Spring..
Hermyboy3000
Do you know where all the drains are? Or do I have to disassemble again?
Hermyboy3000
Thanks Don! As always, you da man!
