FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I noticed that my V cross members don't have a drain hole, they fill with salt water.
Would I cause any structural weakening if I drilled a small hole at the bottom of each?
My two cents worth. When rinsing at home water will stay in the cross member. No driving after it is parked. Good question as I have wondered that myself. I actuall run water into the crossmember on purpose to get the salt out. If left in it will rot out the metal (aluminum).
I have been running the hose in the ends when I get home.
I went ahead and drilled an 1/8th inch hole in the center of each one, I bet at least a half gallon of water came out.
Thanks for the input guys.
