draining gas tank on 85 bayliner
Old85
I am trying to drain the gas tank, Ive got a hose on the barb routed out the drain plug hole. I put one of those hand pumps on it, the kind you change the engine oil with.
I got about a gallon out of there...it never flowed really well...I thought it would act like a siphon, once I got it going just pull the hose off and let it fill the can on the ground but it just petered out.
It seemed to develop a vacuum also, especially towards the end, I pumped and pumped, and it held a huge vacuum on the drain hose but no gas. (The tank is vented so why the vacuum?!?)
I have never used the main tank except once after putting 5 gallons in it and it ran badly. I think it has at least 4 gallons left in there.
How do I get it out?
I wonder if the pickup is clogged hard with some goo!:eek:
Thanks for any ideas!
Ron
Old85
Re: draining gas tank on 85 bayliner
CLOGGED.
It occurred to me right after I posted the above message...
I tried to blow back into the tank, and couldnt do it. Its clogged. Now have to see if I can access the pickup at all.:D
Fun fun fun!!!
Fishermark
There is an anti-siphon valve on the tank - it keeps the gas from siphoning out in case of a fuel line rupture. Sounds like it is working! ;)
Having said that, you should certainly be able to pump the gas out. It could very well be clogged. Your vent line may also be clogged - try removing the fill cap and try it again.
zbnutcase
You may, if you have access, remove the gauge sender and have a look inside...
mike343
Get some 3/8 hose and a in-line fuel pump (like on outboards) and siphon it out.
