redfury
- Jul 16, 2006
- 2,655
A question I've been pondering for a while has me wondering that the consensus here is on drain plugs.
I'm aware of 3 different types. The Garboard style plug ( screwed in from outside the boat ), the rubber expansion type, and the plastic style with the anti siphon ball w/plastic tab to keep from dropping or losing the actual plastic plug.
Since so many here are redoing transoms, I thought this was something worth mentioning in this thread, since it doesn't seem to come up as often as I would think it should.
Pros and cons to the different types, best usage for conditions ( salt vs freshwater ), ease of use, technical issues ( debris in bilge for example, or having to be outside the boat to put the plug in ( in case you forgot to before you launched )
