DPS-A Ujoint Bellows
Senior B
Am about due to change my U-joint bellows on my DPS-A outdrive and am having issues with part numbers and what will work. Original was 3841481 then 23075752 ect. My question is will a Sierra 18-2765 work on the newer drives as it did on my previous SX-M drive? Curious if anyone out there has used it. Thanks in advance:)
BRICH1260
My chart is showing the VP bellows is part # 22197130. You might try cross referencing that number if you are set on a Sierra part.
