Dpe 290 clunk sound
Richard frank
I have twin 290 dpe drives one makes a clunk when it goes into gear.I took the double bearing box apart and it all looks good , the gap on the nut on top is within spec, the bearings feel good , seams to have little wear . There is only 300hrs on the drives and work fine .I drained the oil and it was clean with 100 hrs on this season , any thoughts on what would cause it to clunk. Thanks Rick
Re: Dpe 290 clunk sound
what RPM are you at when your shifting? they will clunk if shifting above 650-700 RPM
captmello
You might have to get in the water and feel for play in the outdrives. Play in the outdrive will cause clunking. I know first hand.
