On my 96 DP-S drive, when i raise or lower the lower unit with the trim switch, the pump will chatter when going up or down. It sounds like power is being interrupted momentarily as it's moving. However, if i use the trailer button with the trim button it will go up or down smoothly? Any thoughts or ideas?? Thank you!
