Double temp senders for v4 90hp?
medic one
I recently purchased my first v4 Johnson. (Thank you to the advise here!)
It is a 2001 90hp v4. I know it has a temperature SENSOR used with the S.L.O.W. system. I want to install a temperature SENDER and gauge.
My question: Do I need TWO senders, one on each head? If so then I guess i'd use a switch on the dash to monitor either sender?
Thanks
emdsapmgr
You are thinking correctly. Actually, the two factory devices are called temp switches. Basically an on/off switch used to determine when to turn on/off things like the hot horn and quickstart. I usually run just one temp sender on my V-engines. Figure that if I keep new thermostats in both, that one is enough to tell me when the powerhead gets hot. Certainly, two is ideal, but it's a lot of extra work. It is possible for one head to get really hot. The thing I want to guard against is if I run over a bag with the lower unit, and the block starts to overheat-I only need the one sender will tell me that. You can weigh the pros and cons of each, and do what you are most comfortable with.
bob johnson
I installed a sender in each head and used a switch on the dash to direct either to the temp guage...it didn't work for some reason...I eventually just installed two temp gauges...one for EACH head with its own sender.... I think this is more important than a water pressure gauge.....you can over heat even with good water pressure..... if you see the temps rising... you can at least turn the motor off...to prevent damage.... I also run the water pressure as I think it important.... you have to be pro active.... things happen..... heat kills motors.... you don't really care what the cause is....but if the temp starts to climb to 200...shut the motor off!.....no guessing.
good luck
bob
interalian
good luck
bob
I did that also, with a SPDT switch right under the temp gauge. When you switch from one to the other, the gauge takes a couple of seconds to register properly as the senders need the load of the gauge to show the right reading. I usually leave the switch set for the starboard bank as that's the side more likely to be hot due to it being farthest from the pump.
