Double hose tank fuel connector leaks
schneider244
The fuel connector to my double hose tank (for my 57 big twin) is beginning to leak. I noticed the o ring on the tank side connector is pretty dried up and cracked, hence the leaking. I cant find a replacement o ring anywhere, does anyone know the dimensions of the o ring so I could source a generic online?>
Thanks
Christian
samo_ott
Re: Double hose tank fuel connector leaks
That O ring is easily available at an OMC dealer. $2 each here. Change both. Use dentist picks to do it. search this forum for the part number as it has been discussed before.
F_R
Honorary Supreme Mariner
301824 from any Evinrude dealer. It is not a stock size, so you won't find it in the hardware store. Sierra aftermarket 18-7111 is a poor substitute, as it is an attempt at replacing it with a stock o-ring.
schneider244
Thanks for the responses, I will telephone a dealer.
tmcalavy
Yep...generic rings won't do it...call a dealer or order online.
