I just purchased a brand new Elegante 2005 leftover - and had the following problems. Those with an * are not corrected yet. Had this boat for a few weeks only - I can't believe the lack of quality control for such a beautiful boat. No one should have to experience this many problems with a brand new boat!
* shower sump - blows breaker doesn't work
fresh water pump failed
* cockpit fridge - failed needs to be replaced
* io drive indicators - don't work
* generator - surges up and down - needs repair
oil leak in sterndrive hose fitting - oil all over bilge
* hatches by anchor - latches misalligned flew open on wake bent hinges
* water in engine cylinder - need new engine 496 MPI - Merc just agreed to replace it
sink faucet leaks
washdown outlet on bow stuck open - needed replacement
* engines not in sync 150 rpm difference when sync in center
* canvas does not fit several panels to be replaced snaps just don't reach
* loud groan from engine hatch hinge when opening - every time
* snaps pulled out/missing
bilge pump failed - needed replacement
Now the boat can't even be used at all with one engine hydrolocked with salt water in the cylinders. I would really like to hear from Doral on what can be done to make it right. NJ has such a short boating season and I am spending it with my new boat in disrepair.
Roger Schechter rogerschechter@verizon.net
sink faucet leaks
