Doral 310 Waste/Water level gauges
Camelot2
I have an 02 Dorall 310
The gauges have not worked since I bought the boat in 2011.
Given they both dont work one would naturally think of the elevtronics in the panel. That being said the likely failure is the sensors themselves.
All that being said, where can I access the sensors?
Charlie
Camelot2
Re: Doral 310 Waste/Water level gauges
Duh....Thanks
Are the sensors accessed from the engine compartment or somehow through the aft?
MolsonCanadian
The sending units are typically mounted through the top of each tank. On my prestancia the waste tank unit is accessed via the aft cabin, under the cushions. The fresh water is midships in an access panel in the floor.
Slip Away
Duh, it depends on what type of sensors you have, how you get to them. Some sensors are internal to the tanks, some are external. The type you have will determine how you can access them.
Likely some cabin/mid cabin tear downmay be required if they are internally mounted.
cptnboom
Did you get the problem fixed? We have the same issue. What did you have to do to fix it?
