sam60
Thread starter- Joined
- May 21, 2011
- 3,189
Regular muffs should work fine for your engine and drive. No visegrip clamps, no special fitting or anything like that. If you need that, then you have a problem you are trying to work around not fix.
My personal view of the fitting in the housing ----------- :facepalm:
Junior is winning again tonight.
Are you giving it some throttle when you start it
The whole idea of this is why spin an obsolete impeller if you don't need to...?
If your are going to do this, and remove the housing and what not, why not make a backing plate that covers up the inlet from the lower, so your water can only go in instead of out you should be able to have someone with a laser cut you one out of 1/8th acrylic... if you wanted to send me your backing plate, I can make you one
I'm confused...what is an obsolete impeller?
The one's they quit making years ago that fits my boat and you can't find them for less than $125 unless your lucky or real crafty.
The one that I'm making now should get dual facepalms....![]()
Here is today's version. This works great! My lower unit is contoured at the inlets and muffs leak bad.
1/4" plate, 1/2" pipe tap and a trip to home depot, problem solved.
I refuse to spin another impeller on muffs. I'll make a gasket for it this week and clean off the RTV. Water was coming out of the exhaust (and exhaust only) within 3 seconds of opening the valve. Can I get a dual facepalm?
View attachment 155790View attachment 155791View attachment 155792
The engine was running in the first 2 pics.
